Bluetooth Connection issue
(Topic created on: 10-20-2025 01:22 AM)
Rouhie
Beginner Level 3
After the recent One UI 8 update the bluetooth doesn't automatically conmect the Audio to the car Bluetooth , it only connects the calls, i have to manually toggle on the audio option few times (it keeps going off ) to connect.
Unfortunately i have to do these manual steps everytime i try to connect the BT.
I have tried all kind of resets but it's still the same
6 Comments
RohanAhmed812921
Mh86
The issue from the new update , android 16 , Samsung team are working to fix this issue.
Doc_Saifi
Beginner Level 4
Same issue here on Samsung galaxy z fold 5
Samsung_specialist
Hello Rouhie, thank you for sharing your issue Kindly check the below steps to solve he issue :
STEP 1. Check for your Bluetooth device's connection
STEP 2. If it's the first time pairing your devices, check to see a pop-up appears on the screen (Pairing Mode)
STEP 3.
Ensure your Wearable app and Bluetooth device software are all up to date.
Bluetooth connection may be interfered with by an abrupt movement or distance between devices over 33 feet(10 meters).
Placing metallic stickers near the antenna or using metallic protection covers can cause pairing problems. Being in a crowded area is also one of the causes of the interference with the Wi-Fi connection and Bluetooth bandwidth(2.4GHz).
How you confirm your Bluetooth connection may differ depending on the pairing device. Check your device's manual to properly put it in a pairing mode.
(E.g. Buds: Place your buds back in their case, and close the lid. Then, reopen it.
Headphones: Press the Power or Call button for 7 to 8 seconds. The LED will blink and go blue to indicate the connection is established.)
Also you can try the last step before visiting the service center go to setting > General management > Reset >Reset Wi-fi and Bluetooth settings.
Rouhie
Beginner Level 3
I havw followed those steps couples of times but unfortunately the problem is still persists .. i guess the only option is reset factory setting
Samsung_specialist
We're sorry to hear about your experience.
Also, for more support you can visit a service center via this link : https://www.samsung.com/ae/support/service-center/.
