Car Bluetooth connection
(Topic created on: 11-20-2025 07:30 PM)
MichelEltlahy
I'm facing an issue with Car Bluetooth connection Undoubtedly that issue from the phone.
Do you have that issue?
3 Comments
mZoOnY
Right now actually I'm not facing issues with bluetooth of my phone when interfacing with vehicle.
I'm using my S23 ultra from past 4 years.🙏
Samsung_specialist
Thank you for contacting us and sharing your concern regarding the car Bluetooth connection. We understand the inconvenience and would like to assist you. Please try the following troubleshooting steps:
  1. Update your device software: Go to Settings > Software update > Download and install to ensure your phone is running the latest version.
  2. Forget and re‑pair the connection: Navigate to Settings > Connections > Bluetooth, select your car’s Bluetooth profile, tap Forget, then re‑pair it again.
  3. Clear cache partition: Power off your device. > Press and hold Volume Up + Power until the Samsung logo appears. > Use the volume keys to highlight Wipe cache partition and confirm with the Power button.
  4. Reset network settings: Go to Settings > General management > Reset > Reset network settings. This will refresh Bluetooth, Wi‑Fi, and mobile connections.
  5. Safe mode test: Restart your device in Safe Mode (press and hold Power > tap and hold Power off > Safe mode) to check if a third‑party app is interfering with Bluetooth.
If the issue persists after completing these steps, we recommend visiting a Samsung Service Center for a full inspection. You can locate your nearest center here: Samsung Service Centers.
