05-04-2025 10:22 PM in
Galaxy S- Mark as New
05-05-2025 01:46 AM in
05-06-2025 10:26 AM in
Galaxy SWe’re truly sorry to hear about the inconvenience you’re experiencing, try the below steps that may assist you.
1. Clear Cache: Go to Settings > Apps > One UI Home > Storage > Clear Cache.
2. Update Software: Ensure your device is running the latest software version by going to Settings > Software Update > Download and Install.
3. Disable Unnecessary Features: Check for any unused features or widgets that may be consuming battery.
4. Force reboots your device by pressing and holding the power and volume down buttons simultaneously for more than 7 seconds and your device will reboot.
