01-07-2022 12:16 AM in
Galaxy SSolved! Go to Solution.
01-07-2022 11:39 AM in
Galaxy SHi, Grant82 backup your data and reset your phone to factory.
1. From the home screen, swipe either up or down to access apps.
2. Select Settings.
3. Select Accounts and backup
4. Select Backup.
You can also backup and update using Samsung Smart switch. Herewith Smart switch link:
https://www.samsung.com/za/support/smart-switch/
Install the program on your computer and connect your phone to your computer using an Original Samsung cable and follow the prompts.
2. Select Settings.
3. Select General Management.
4. Select Reset.
5. Select Factory data Reset.
6. Tap Reset.
01-07-2022 12:40 AM in
2. Select Settings.
4. Select Backup.
2. Select Settings.
4. Select Reset.
6. Tap Reset.
01-09-2022 05:01 PM in
