Camera quality problem
(Topic created on: 03-15-2022 09:59 AM)
Ayazkhansuperstar
Galaxy Note
I don't know what happened to my Note 8 camera quality is very bad now🤔
6 Comments
RickBro
Galaxy Note
Did you update your firmware recently?
Tsogo_sam05
Galaxy Note
Hi, Ayazkhansuperstar please follow the steps below to do this:
1. From the home screen, swipe either up or down to access apps.
2. Select Camera.
3. Select Settings.
4. Select Reset settings.
5. Tap Reset.
Galaxy Note
I did reset the settings
DatGuy
Galaxy Note
Bad with all the apps or just main camera app?
Tsogo_sam05
Galaxy Note
Hi, Ayazkhansuperstar kindly backup your data and reset your phone to factory.
2. Select Settings.
3. Select Accounts and backup
4. Select Backup.
You can also backup and update using Samsung Smart switch. Herewith Smart switch link:
https://www.samsung.com/za/support/smart-switch/
Install the program on your computer and connect your phone to your computer using an Original Samsung cable and follow the prompts.
2. Select Settings.
3. Select General Management.
4. Select Reset.
5. Select Factory data Reset.
6. Tap Reset.
Galaxy Note
Personal contact number!
