2347
a week ago in
Consumer Electronics
I have a problem with registration of my finger print , says i have to contact customer service
7 Comments
SherlockHolmesB 221
a week ago in
Hi. Please tell me what phone you are using?
2347
a week ago in
A33
The-Kid-Deė
a week ago in
Did you replace the screen??
2347
a week ago in
Yes
The-Kid-Deė
a week ago in
That's why, make sure you replaced with an original screen that supports Underdisplay fingerprint then take it Samsung to calibrate the sensor.
2347
a week ago in
Thus is an original screen i replaced the broken one with
SherlockHolmesB 221
a week ago in
Hi
If your Galaxy A33 says “Fingerprint registration failed — contact customer service”, that usually means the fingerprint sensor isn’t being recognized properly, but it can often be fixed without a repair. Let’s go through it step-by-step 👇
🔹 Step 1: Basic Checks
1. Clean the sensor – Use a soft, dry cloth to gently wipe the fingerprint area.
2. Clean your finger – Make sure it’s dry and not oily or wet.
3. Remove screen protector (temporarily) – Some thick or non-Samsung protectors interfere with fingerprint registration.
🔹 Step 2: Software Reset of the Sensor
1. Go to Settings → Biometrics and security → Fingerprints.
2. Delete all saved fingerprints.
3. Restart your phone.
4. Try registering again in a well-lit room and ensure you’re pressing the entire thumb area.
🔹 Step 3: Safe Mode Test
This helps see if a third-party app is interfering:
1. Press and hold the Power button → Tap and hold "Power off" → Choose Safe Mode.
2. Once in Safe Mode, try to register your fingerprint again.
If it works here, an app is causing the issue. Restart normally, then uninstall recent or suspicious apps.
🔹 Step 4: Software Update or Cache Reset
1. Go to Settings → Software update → Download and install.
Sometimes fingerprint issues are fixed in patches.
2. If it’s still stuck:
Boot into Recovery mode:
Turn off the phone.
Hold Volume Up + Power until you see the Samsung logo.
Use volume keys to select Wipe cache partition, then press Power to confirm.
After that, select Repair apps (if available).
🔹 Step 5: Last Resort
If none of the above works, it could be a hardware fault in the fingerprint sensor.
Visit a Samsung Service Centre.
If your phone is still under warranty, they’ll repair/replace the sensor free of charge.
Turn off the phone.
