Health monitor not working
(Topic created on: 12-04-2024 06:57 PM)
ahmedmorsy123
Beginner Level 4
Wearables
I bought galaxy watch 7 and samsung health monitor say not available in your country any idea how to fix this
2 Comments
Didionpc
Wearables
It sounds like you're encountering a common issue with the Samsung Health Monitor app. This app is not available in all countries due to regulatory approvals and restrictions. Here are a few steps you can try to resolve this issue:
Check for Updates: Ensure that both your Galaxy Watch 7 and the Samsung Health Monitor app are updated to the latest versions. You can check for updates in the Galaxy Store.
Change Region Settings: Sometimes, changing the region settings on your phone and watch to a country where the app is available can help. However, this might require a factory reset of your devices, so proceed with caution.
Use a VPN: Using a VPN to change your location to a country where the app is available might allow you to download and use the app. Be aware that this might not always work and could have legal implications depending on your country's regulations.
Contact Samsung Support: Reach out to Samsung support for assistance. They can provide you with the most accurate information and potential solutions based on your specific situation.
Wearables
If you are in other GCC countries than UAE then Health Monitor will not work.
