screen problem
(Topic created on: 01-08-2018 02:11 PM)
Justmissingyou
I have a problem with my s7 edge it show LIKE a purple dots and green line 5f4941b9-1391-4573-8430-664bafd53e6f.jpg
9 Comments
ArtGrapher
OMG , it's awful , unfortunately the pixels of your screen are burning and it will increase , you might better change the screen as soon as possible
thank you
Cookie1
Jesus, mine also mine shows little bit of same symptoms..
The warranty of my phone has expired. And this purple/pink lines shows only on low brightness.
I pray to god that it doesn't show up all of a sudden like what happened to other people.
Can you tell me when you purchased your phone and after how long this showed up??? Thanksb770f149-e724-45ba-8829-e078d3e3df4f.jpg
you can say about 1 year .. and also mine shows LIKE yours in low brightness
Samsung say.. that the pixel of t he phone screen has burn.. but I will change the screen
Cookie1
Have you tried resetting the screen on *#0*# ???
how to rest it ?
Cookie1
type *#0*#
Then press "Red"
then "Green"
then "Blue"
this will reset the pixel colors..
i do this when the screen shows little bit of abnormal colors like pink, green lines.
ok thanks ❤
