s7 edge is automatically restarting with in 30mint
(Topic created on: 11-20-2016 12:27 PM)
Nitheesh1
Beginner Level 5
if someone have the same problem? or suggest me how to slove this restarting issue
6 Comments
kamran9
in settings have autorestart turn off it
Nitheesh1
Beginner Level 5
I have checked with the settings it's turned off .I have reset the phone now it's seems to be oke and thanks for the reply kamran
johnSJB
Beginner Level 3
factory restore first. after check your device.
ahtesham1
I am suffering from the same problem
ahtesham1
factory reset? and hiw I can save my data
Nitheesh1
Beginner Level 5
I have factory restored my phone just save it data's in sd card by using smart switch and my problem was sloved
