problem on wifi connection after upgrade to nougat 7 in s7 edge
(Topic created on: 04-22-2017 03:08 AM)
yum1
since, I upgraded my S7 edge to Nougat 7 there is problem seen on wifi connection. Its not connecting the wifi properly. Although it connected it shows poor network and no internet access. But on the same wifi to other phone work well at the same time. so please is there any solution for this problem.
3 Comments
Adhith
This usually happens on first use. Try restarting your phone and this should be solved.
imthi1
try to change WIFI router i had a same problem after update my s7.
after that i have change the router now there is no issue.
yum1
thnks alot...
