how to change location of edge and edge opacity in nougat?
(Topic created on: 04-15-2017 11:23 AM)
frasit
before updating to nougat i had simple option to change the location of my edge screen...but after update i am unable to find the option in settings..anyone who found it?
4 Comments
go to settings,display,EDGE screen,option. then edge settings appear
frasit
there is no options tab available inside edge screen in nougat
if you not seen than you are mad
KHAN86
i found it . from the settings go to edge screen from the edge screen go to edge panels and in the edge panel there will be 3 dots on the right corner of the screen tap on it a drop down menu will appear from that drop down menu choose "handle settings" and from there u can choose the location of the edge screen. tell me if it worked
