help
(Topic created on: 06-21-2019 08:41 PM)
shawnoloye
I have a question..... i steped on my s7 edge and there is ink spot on the screen now. Does that affect the waterproof capacity.??
2 Comments
As long as you don't have a major cracks and the sides of your screen are still sealed you don't have to worry,but you will only have this annoying spot on your screen.
It's a crack on the LED panel. As long as there are no visible cracks on the gorilla glass and the pannels, it will not affect the water resistance.
