Stuck on USSD code running. Help please
(Topic created on: 03-16-2025 02:14 PM)
light123
Beginner Level 4
Hey guys, whenever I try to take data in my du sim by dialing *135# it shows USSD code running and it doesn't go away till I restart the phone. Can anyone help please? My phone is Samsung s23 ultra
EDIT:
Solved !
 Turn off VolTE Calls under Settings -> Connections -> Mobile Networks
Credits to reddit and the user here who asked me if it is only happening with du..leading me to search in that direction.
Thanks all❤️
4 Comments
omkc50
Switch off and restart once if not solve please proceed to nearest samsung authorized shop. Don't listen suggestions from anyone
ojwh
Hello. Are you having issues with all other USSD codes you run, or only with Du?
light123
Beginner Level 4
Only with Du
ojwh
Hello OK. Not sure what's going on, but sometimes, operator codes can have issues.
As a workaround, in the meantime, especially if you usually have access to data, you can use the Du app to manage account related activities:
https://play.google.com/store/apps/details?id=duleaf.duapp.splash
