07-15-2019 10:34 PM in
Galaxy SIn my Samsung S8 running Android 9 with security patch 1-Jul-2019, it doesnt show up incoming call answer screen. Instead it prompts to input password with a button "Return to Call". This is very annoying prompt everytime to answer calls / dismiss alarms, calendar reminders. This is happening for quite few months.
I have tried couple of solutions from Samsung US community. But doesnt work for me. Please help.
Incoming call screen
Solved! Go to Solution.
- « Previous
- 1
- 2
- Next »
07-16-2019 07:34 PM (Last edited 07-16-2019 07:34 PM ) in
Galaxy SGo to settings > apps > click on the three dot menu on the right top > special access >Appear on top and turn off all thirdparty apps. Restart your phone and try ringing your phone again. Check the screenshots attached. This is a screenshot from my Note 9. Some option may vary in your device.
07-17-2019 01:10 AM in
Galaxy SI followed steps you mentioned with three below combinations in Appear on Top settings and did restart every time.
> First disabled only third party apps.
> Disabled all apps.
> Disabled most of system apps also except Call, Phone Services and UI.
Everytime i restarted, it worked (no unlock prompt) for 2 or 3 incoming calls with phone locked for every attempt. Then again unlock prompt is back during incoming call.
Then I Reset App Preferences in Appear on Top. Now new problem: everytime i restart phone, during first incoming call phone screen lights up but Call is not displayed.
07-17-2019 03:16 AM in
Galaxy STake a backup and reset the device. Use smart switch to backup. It will backup all app and data in the device.
07-17-2019 11:11 AM in
Galaxy Sahh... how do i make sure the very same app or settings that triggers unlock prompt (during incoming call) does not happen when i restore from backup?
07-28-2019 03:16 PM in
Galaxy SThanks for helping. I reset the device and restored except Settings to be sure. Let me try installing caller ID app.
- « Previous
- 1
- 2
- Next »
