Resolved! Solved
S8 not showing incoming calls / alarm screen when screen is locked
(Topic created on: 07-15-2019 10:34 PM)
Meyapan
In my Samsung S8 running Android 9 with security patch 1-Jul-2019, it doesnt show up incoming call answer screen. Instead it prompts to input password with a button "Return to Call". This is very annoying prompt everytime to answer calls / dismiss alarms, calendar reminders. This is happening for quite few months.
I have tried couple of solutions from Samsung US community. But doesnt work for me.  Please help.
Incoming call screenIncoming call screen
Take a backup and reset the device. Use smart switch to backup. It will backup all app and data in the device.
14 Comments
Have you installed any thirdpary app either to display caller id or some note taking app that works during calls?
Meyapan
Thanks for your reply. Yes, I got TrueCaller.
Meyapan
I uninstalled TrueCaller, but still problem persists.
Ok, have you disabled notification on lock screen?
Meyapan
i tried with Lock Screen > Notifications on and off. This notifications takes effect only on highlighted app notifications. (screenshots attached).
still the problem persists, that is, with Lock Screen notifications disabled pin prompt is displayed during incoming call.
Ok, Try using your phone in safe mode. For entering safe mode,
1. Switch off your device.
2. Press and hold the power button until the device shows "SAMSUNG S8". (Till booting)
3. Release the power button and press and hold volume down button until device bootsup completely till you can see the home screen.
If you see SAFE MODE on the bottom left corner, your phone is in safe mode. If not repeat the steps until the phone is in safe mode.
Now try to ring your phone and let us know the result.
Third party apps will not work in safe mode. To exit from safe mode, restart your device.
Meyapan
Yes it worked fine now in safe mode - there is no pin prompt during incoming call (Attached image). i could straight away respond to incoming call. i got back to normal mode. just out of doubt, removed couple of call recording apps. But still problem persists. how can i find out which third party app is triggering phone unlock prompt during incoming call?
http://apps.samsung.com/appquery/appDetail.as?appId=com.samsung.android.app.goodcatch
Download and install the app from the link, which is developed by samsung to dectect which third party app sent you random notifications, adds, etc. Am not sure whether it can dectect which app is causing this issue on lock screen.
Install the app, open it, give all necessary permissions and then try to ring your device. After unlocking the phone, open the app again. There is an option called TOAST HISTORY with in the Nice Catch app. Its shows which app displayed a popup message on the screen. Also check other options in the app. If you find something suspecious let us know.
Meyapan
Installed Nice Catch app but there was no persmission prompt when i opened it. All history enabled (screenshot attached). I called my device but dont see any event in Toast History. However i could see incoming call event as "Call Management" in Callmode History.
