S7 Edge restarts randomly and can't be updated !!
(Topic created on: 04-21-2017 04:41 PM)
Hossary
Beginner Level 4
My s7 edge ( UAE version ) restarts randomly more than 3-4 times / day !!
Im on andoriod version 6.0.1 and i can't update my phone . every time i download the software package and on installing it always breaks at 26% without a reason .. please help and thanks in advance
5 Comments
Subzero355
have you tried to perform a factory reset?
Yazdanie
do soft reset.
Adhith
Should be some bug in the software. Try doing a factory reset.
tammeryousef
update your phone via smart switch at pc . that's for sure will fix your problem
Hossary
Beginner Level 4
i did factory resets more than five times and i disabled preinstalled facebook application and the problem still exsists
