S6 edge fast charging not working ?
(Topic created on: 11-27-2017 03:10 AM)
RiZ69
i tried everything buying different fast adapter and cable but still cable charging when i tried in S7 it was showing fast charging
first i thought maybe In settings it's off but fast charging was turned on
i thought maybe charger flex problem replaced it still same no improvement
last option was resetting but i have data this phone Doesnt even connect in laptop so i could create backup and reset
7 Comments
Neilrose
maybe your connector and adopter are fake?
RiZ69
techician tried on different S6 edge it works and adapter is tested fast charging works on S7
abz1
try to charge ur phone in safe mode
RiZ69
i tried that already
RyoSan
dude mostly this is ur charging port is dead as you cant connect to laptop also fast charging is not working its more than 99% the usb connection port in ur device need replacing
Blade1
perhaps your phone is kindly asking you to buy s9
RiZ69
maybe but i can't afford it
