Resolved! Solved
S25 ultra Problem with slow conversion to microphone or other lag
(Topic created on: 02-06-2025 02:32 PM)
foxonlyy
There's a problem with the S25 Ultra slow up.
When you choose Spiker Delayed Spicer Mode
When the spiker mode is stopped, it is also delayed, and this is an explanatory video of the problem. Please resolve the issue as soon as possible because the issue is disturbing.
Samsung_specialist
Plaese raise the isuse from the member app , https://www.samsung.com/ae/support/mobile-devices/raising-an-error-report-via-samsung-members-app/
and you may raise it form insid the app itself Open the phone app on your mobile device.
three dost , select "Contact us" and then "send feedback."
Check the box next to "Send system log data."
12 Comments
yousefhbk
No issue you have to wait for next month security update they will fix bugs on new version it's only a trail 😉
That's way too long to suffer 😆
yousefhbk
Than you should had patience 😌 👌
Ya the only way left out
This should be a software related bug 🤔
1. Restart your device .
2. Clear chace of the samung sound application or any of the other audio apps
3. If things didn't work, reset the sound setting
There's no such thing.
Do u use sound assistant ?
no
Reset Sound Settings - Navigate to Settings > Sounds and Vibration > Advanced Sound Settings > Reset to Default.
