S23 Ultra - GPS not working/ low accuracy
(Topic created on: 06-06-2023 06:30 PM)
DeepKing47
My S23 Ultra has an issue with its GPS,
Anyone facing problem with the GPS ?
Any solutions ?
17 Comments
Try this:
1. Turn on location services
2. Disable battery optimization.
3. Use high-accuracy mode.
4. Reset GPS settings
5. Restart your device
DeepKing47
Tried everything
salmanul
Expert Level 3
Turn on precise location for Google map
And calibrate the compass accuracyScreenshot_20230606_235158_Permission controller.jpg
DeepKing47
Already turned on,,
I tried some GPS testing apps also , those apps not showing any issue with the GPSScreenshot_20230607_025434_Permission controller.jpg
salmanul
Expert Level 3
Please visit authorized service center, so you will get a clarity and a resolution
DeepKing47
I am waiting for the update, maybe that will fix the issue
kmizeta
I'm also having 7 or more meters of inaccuracy in my S23U, on all GPS apps. Tried all methods to reset it, also I've activated the Force GNSS option and the issue persist. I have used GPSTest app to estimate the inaccuracy, sometimes I get 9 or 10 meters. Firmware version AWGJ.
DeepKing47
I got mine repaired from the service center
They replaced it's motherboard
Now the GPS working fine and the network reception (mobile network and Wi-Fi) is also increased
