Nougat update battery issues
(Topic created on: 11-18-2017 08:12 PM)
venki5316
i am asking help to you guyss many times but you people not even giving a proper feedback no response only you guys are saying send a mail there also not even a single reply from your team please help me out and also my battery is draining out quickly
5 Comments
Blade1
easy solution. sell the phone and get yourself pixel 2/2XL or OnePlus5/OnePlus5T
Faisalkhan1
Good advertisement
*reporting this comment*
edit: these days people buying s7 edge for 250 to 300 us dollar. If you open it from box or use them
Blade1
you better report zero support by Samsung. not a single answer to any question posted in this community. the best advertising for the handsets running stock or close to stock Android- is my UAE Note 8 being on the August security patch in the second half of November.
author of this thread asked to solve the problem caused by low quality of the firmware optimisation. To solve this problem one needs to buy smartphones running close to stock Android. I posted in another thread useless answer I got from Samsung Support for the absence of any new security patches/updates for the Note 8 since August
Subzero355
May i ask how quick it drains? like how many % in an hour?
FidaHussain1
Note and S8 series are down because in the cheap mobile you add extra and advanced features like J7 pro series and A7 series in which both cam are 13 mps and dual fb twitter and whatsapp
Why Samsung didn't add these features in Note 5 and S7 edge even in the Note 5 their is not a Memory card slot for external memory what's the game samsung and also you give edge to new Note 8 why
I hate edge because their is a more chances of damages.
Please Samsung in the next series of Note 9 not to give edges in this Galaxy phone
And know please upgrade the Nougat for Note 5 and add some dual features and some more please.
