Mobile data disconnects automatically and doesn't connect again
(Topic created on: 03-29-2017 11:05 PM)
AbuTurabK
Hi. My hand set is SM-G935FD. I'm facing problem with the mobile data when I use dual Sim. I use 1 Sim for calls and texts while the other for data. But the problem is that mobile data disconnects automatically and then doesn't connect again unless I turn off the data Sim and turn it on again. Restarting the phone doesn't help. Data disconnects even while using or when phone is idle.
I never faced any such problem while using single sim.
Please help in this regard.
3 Comments
anee
try putting the data sim in slot 1
AbuTurabK
Already tried.....
savagejohn2
take your phone to your closest tech store
