How did i get 0% battery
(Topic created on: 10-19-2025 09:03 PM)
-Carter-
3 Comments
BasilJJ
By not charging
wolfmen
This happened to me also
Samsung_specialist
Thank you for sharing the screenshot. If you are facing battery usage issue you can check the link for the steps:
https://www.samsung.com/ae/support/mobile-devices/the-battery-drains-fast-how-do-i-extend-the-batter...
