Help my S23 Ultra before I commit a crime against it
(Topic created on: 01-03-2024 07:50 PM)
Hebazzz
I'm trying to understand why this keeps happening even though my notifications are not too frequentand when ever I receive a notification I remove it. Moreover the UI system apps and Google play which I hardly use!!
I even turned off all the special features including the basic ones likea location, NFC, Dolby and Bluetooth!
Why does this keep happening, draining my battery extremely fast while not in use!!! I'm losing my mind here over this and cannot use my mobile properly, it scares me that if I touch it, it will keep draining the battery😒
Note: I followed Samsung recommendation for battery optimization and Apps background usage limiting, so please do not give these advices.
6 Comments
If you've already optimized your battery settings and limited background app usage, yet the battery drain persists, here are a few additional steps you can consider:
1. **Check for Rogue Apps:** Review recently installed apps, as one of them may be causing excessive battery drain. Uninstalling or disabling suspicious apps might help.
2. **Battery Usage Stats:** Go to your phone's settings, find the battery section, and review the apps consuming the most battery. This can provide insights into the culprit.
3. **Safe Mode:** Boot your phone in safe mode to see if the issue persists. This helps identify if a third-party app is causing the problem. If the battery drain is minimal in safe mode, it's likely an app issue.
4. **Background Processes:** Some system processes or third-party apps may still run in the background. Use a task manager or monitoring app to identify and stop unnecessary background processes.
5. **Check for Updates:** Ensure your phone's operating system and apps are up-to-date. Manufacturers often release updates to fix bugs and improve battery efficiency.
6. **Factory Reset:** As a last resort, consider performing a factory reset. This will revert your phone to its original state, eliminating any software glitches or conflicts. Remember to back up your data before doing this.
If the problem persists, reaching out to Samsung support or visiting an authorized service center may be necessary for a more in-depth analysis and resolution.
FadiAbuAzeh
My advice is to wait for the next update,it might help, if not, here is my suggestions and thoughts, visit the customer service to check your phone and if it doesn'twork, then here is my thoughts, since we are close to launch s24 Ultra, Samsung may did it to force us to upgrade to s24 Ultra.
Zammi
In settings, goto Apps and search for Google play services. Tap on it and scroll down and tap App details in store. It should take you to Google play. Check if Google play services is trying to update and stuck. If that's the case cancel and update again.
Zammi
Try power saving mode for a day to see if the difference is huge. If the difference is huge, it is better to backup your data and factory reset. When restoring, don't restore the settings.
Samsung_specialist
Kindly visit the Service center for further checking.
Hebazzz
Will you be able to provide me with the address in Dubai?
