06-21-2023 02:50 PM in
Galaxy SSolved! Go to Solution.
06-21-2023 03:21 PM in
Galaxy S- Mark as New
06-21-2023 03:46 PM in
06-21-2023 03:49 PM (Last edited 06-21-2023 07:20 PM ) in
06-23-2023 09:05 AM in
Galaxy SKindly note that the expert RAW and Pro mode are two different shooting modes on the Samsung S23 Ultra. Expert RAW saves a multi-frame 16-bit RAW image, which has more detail and dynamic range than a single-frame 12-bit RAW image saved by Pro mode. This means that Hello,
Expert RAW images can be edited more flexibly in post-processing. However, editing RAW files can take more time than editing JPEG files. So, if you want the best possible image quality and are willing to put in the time to edit your photos, then Expert RAW is the way to go. Otherwise, Pro mode is a good option.
02-25-2024 08:55 PM in
Galaxy SProMode produces fakes that have no advantage over the jpg.
ExpertRAW has compression artefacts in dark parts of the image.
a month ago in
Galaxy SI know this is old but still in August 2025 the expert raw keeps showing artifacts in dark areas because of the compression but I noticed that it only happens in high resolution images, it doesn't happen with a 12mp picture
08-16-2024 10:52 PM (Last edited 08-16-2024 10:54 PM ) in
Galaxy SSamsung have broken everything they can to make room for new models, never again any product from Samsung . I have wasted a lot of time testing their faulty camera software, every mode is useless, files are created with artefacts, colour spots and as you can see they do nothing about it. . Samsung, you are running out of time to regain your honour.
