Can't turn off screen using power button while whatsapp audio calls
(Topic created on: 12-10-2024 12:03 PM)
Adilvahab
During Whatsapp audio calls (both personal and business accounts), i can't turn off the screen using power button as i have to keep it in pocket it will be difficult as it occurs accidental touches.
Please do provide any solution I have tried updating to newer updates still issue is not fixed.
2 Comments
hafiz387
send bug report in setting section. they will fix automatically
Didionpc
Check WhatsApp Settings:
Open WhatsApp and go to Settings > Chats > Screen Lock. Ensure that the screen lock feature is enabled.
Enable Proximity Sensor:
The proximity sensor should automatically turn off the screen during calls when the phone is close to your ear or in your pocket. Make sure this feature is enabled in your phone’s settings:Go to Settings > Advanced Features > Motions and Gestures > Proximity Sensor.
Update WhatsApp:
Ensure you have the latest version of WhatsApp installed. Sometimes, updates fix bugs related to screen behavior during calls.
Restart Your Phone:
A simple restart can sometimes resolve temporary glitches.
Check for System Updates:
Make sure your phone’s software is up to date. Go to Settings > Software Update and check for any available updates.
Use a Screen Lock App:
If the issue persists, you might consider using a third-party app that locks the screen during calls.
If none of these solutions work, it might be worth reaching out to Samsung support or WhatsApp support for further assistance.
If your question has been answered, please press the "Accept as Solution" button. There are three dots to the right of my comment.
