Camera problem
(Topic created on: 02-06-2026 01:54 AM)
azgorhosen
When i take picture then picture is not clear coming.. its total picture coming blur.. please update for samsung s25 ultra version UI8.5
4 Comments
It’s frustrating when your flagship camera doesn't give you the clarity you expect. Since the S25 Ultra has a massive sensor, it requires precision. Here is how to fix the blur issue before waiting for future updates:
​1. Optimize Camera Settings (Quick Fix) ​Open the Camera App > Tap the Settings (Gear icon). ​Go to Intelligent Optimization. ​Set it to Minimum. This reduces processing time and helps capture moving subjects without blur. ​Also, ensure "Scene Optimizer" is OFF if you are taking photos of moving objects. ​2. Check the Focus Tracking ​In Camera Settings, make sure "Tracking auto-focus" is turned ON. This helps the lens stay locked on the subject even if they move slightly.
​3. Use "Camera Assistant" (Expert Tip) ​Download the Camera Assistant app from the Galaxy Store (it’s an official Samsung module). ​Enable "Quick Tap Shutter" – this takes the photo the instant your finger touches the button, reducing motion blur.
​Set "Prioritize Focus Over Speed" to find a balance that works for you. ​4. Hardware Check ​The S25 Ultra has a very shallow depth of field. If you are too close to an object, the edges might look blurry. Try stepping back and using the 2x or 3x zoom instead. ​Make sure there is no protective film or smudge on the 200MP main lens. ​5. Regarding UI 8.5
​Samsung usually improves camera algorithms with every major update. While we wait for future versions like UI 8.5, keeping your current software updated and using the settings above will significantly improve your photo clarity.
If your question is answered, press three points above and press the solution is accepted, and thank you for your question.
Samsung_specialist
Thank you for sharing your feedback regarding the camera performance on your Galaxy S25 Ultra.
Blurry photos can occur due to camera settings, focus behavior, or environmental conditions. We recommend ensuring the camera lens is clean, checking that auto focus is working properly, and updating the device software to the latest available version. You may also review camera settings such as intelligent optimization and scene optimizer to achieve better clarity depending on the shooting conditions.
Please note that camera performance is continuously improved through software updates, and future One UI updates may include further enhancements and optimizations.
If the issue continues despite adjusting the settings and updating the software, we recommend visiting the nearest authorized Samsung service center for device inspection:
https://www.samsung.com/ae/support/service-center/
For any additional assistance, you may reach us through the Contact Us page:
https://www.samsung.com/ae/support/contact/
