Battery issues
(Topic created on: 04-29-2025 06:26 PM)
tinmla
Hi is anyone else having battery issues? After updating to one ui7 my battery no longer lasts the whole day and I now charge the phone 2-3 times per day #S24 ultra
7 Comments
Dustiny
What do you usually do with the phone? Gaming? Browsing? Or watching movies?
tinmla
Just your normal browsing and videos same as I was doing before I updated
Mohsin1431
I do have the same issue. I recently cleared the system cache. I hope it will be resolved soon or maybe has resolved for me now.
kingash44
Yup kust very light using now have to charge phone twice a day
kingash44
Just using whatsapp only
Expert007
*#9900# delete dump state. Put app in deep sleep app closed GPS
Majestic_911
It is true that there are some problems with the update, but the problem will be solved as soon as possible.
