Battery drainage issues
(Topic created on: 04-24-2025 09:57 PM)
_moin_42_72
Isn't someone facing battery drainage issues after upgrading to Ul 7.O Update?
10 Comments
blu0wen
Its expected to drain the battery fast since its adjusting the new installed software. It will return back to normal soon after learning and installed all the updates
_moin_42_72
Thanks bro for explaining. Let us see when it is getting back too normal
blu0wen
JP1606
So far, so good for me. No battery issues.
_moin_42_72
That's great 👍
JP1606
I just noticed that it charges slower before updating.
_moin_42_72
May be it will be normal after sometime
JP1606
I hope so.
mohd93
I experienced the same battery draining very fast after installing UI7
