Battery Problem
(Topic created on: 12-23-2016 11:04 PM)
S7E1
Used to, battery drop %1 percent if phone use 36 mah. Now it's dropped %3 percent with 27 mah usage. What's your suggestions? Only Android System draining the battery. (S7 Edge Version)
5 Comments
NoorSolangi
im facing it too.. my s7edge got worst now
Kanaan
often this quick battery draining doesn't come from the device or the system themselves, check your apps which is consuming a huge amount of battery power.
if the problem occurred suddenly, remember which app you have installed recently.
S7E1
Thanks for replies... I found the problem. it's ok now.
shivon
what was the problem & what is the solution ???
teco29
how you found problem
