Samsung One UI 7 Battery Drain Issue -
(Topic created on: 05-02-2025 02:15 AM)
MOQBALI
Community Guidelines
BATTERY
DRAIN ISSUE FIXED
13 Comments
Shukran ❤
I cant see the video..
MH_HASAN
Hi MOQBALI,
I had already suggested this trick to many members here, but some were OK after wiping cache partition but some were still Complaining.
This is because of the type of processor, and there are also some applications to close. For example, games, Snapchat, and YouTube reduce battery life. Open GPS, Bluetooth, and Wi-Fi also contribute. So, some members need to learn about these things. In the end, you and I are trying to help. Some people accept this, while others believe it is a trick.🤝🌹
Agree with you 👍
However, what I had observed that some S24U users are ok after following wiping cache partition but some didn't. My doubt was how is it possible for same model?
S23U were also fine after wiping cache.
That's where I was in dilemma. 😄
NyambK
What if one doesn't have macbook?
No problem it's generally
NyambK
I have tried my s24 ultra but unfortunately i am not lucky.
