system issue
(Topic created on: 07-03-2018 09:15 AM)
RoMaNy
battery draining more fast than before and also many apps need to restart or close
2 Comments
imran122
my a5 2017 is problem after Oreo updates
admin_1
Hi! As per analysis of the logs you shared,; it has been found that many apps are running on the background of your device such as instagram, whatsapp, and facebook. Please exit (close) the applications from multi-task screen for shut down completely them and turn off sync task, notification, alarm of applications if unnecessary apps closing. If issue happen, please get log immediately and raise the issue again
