how to fix fingerprint problem in A50
(Topic created on: 10-12-2020 08:38 PM)
biòoo
How to fix fingerprint problem in a50
9 Comments
What's wrong with your fingerprint unlock?
biòoo
it's not working when I try to reset it always saying calibration needed
biòoo
even I had updated the software it's not working
If you can't reset the fingerprint data then the best solution is to visit the nearest Samsung service centre to flash the android software in your device, this should help you solving your issue.
biòoo
thank you very much
Hiahwqq
I Have 3 Gb Ram I need 8 gb ram for free
Samsung_specialist
Hey there,
Would be best to get the phone checked at a certified Samsung service center. Thanks!
Choppa
sometimes you just need to restart your phone.
factory reset the phone and then add fingerprint. i also faced same issue after doing factory reset its working fine
