Task changer (Home up) problems
(Topic created on: 10-15-2023 12:29 AM)
Not applicable
Why it will not work properly once I change setting in stack but it will automatically switch in default settings
2 Comments
chebern
Same with me 😏
Samsung_specialist
To ensure the best performance and functionality, please follow these steps to address the issue you're experiencing:
Update the App: Start by making sure that the Good Lock app is updated to the latest software version. Updating the app often includes bug fixes and improvements that can help resolve issues. You can update the app from your device's app store.
Clear Cache for Good Lock App: Clearing the app's cache can resolve certain performance issues. Please follow these steps:
Go to "Settings" on your device.
Scroll down and select "Apps" or "Applications," depending on your device's terminology.
Locate and tap on the "Good Lock" app.
Under the "Storage" section, select "Clear Cache."
Uninstall and Reinstall the Good Lock App: If clearing the cache doesn't resolve the issue, you may want to uninstall the Good Lock app and then reinstall it. This can help ensure a fresh installation of the app.
