Issue with LockStar on S22 Ultra
(Topic created on: 03-01-2022 01:32 PM)
ar4ahmad
I discovered the LockStar app on my S22 Ultra and tried customizing the position lock screen items with it. I enabled and disabled it a few times, and tried out different layouts and backgrounds, deciding on one towards the end. However, I noticed that I now have multiple clocks and status bar items on the lock screen. I went back to the LockStar app to fix it, but it doesn't detect this and tries adding a new clock on top.
WhatsApp Image 2022-03-01 at 11.15.05 AM.jpegWhatsApp Image 2022-03-01 at 1.04.12 PM.jpeg
What I've tried:
  • Toggled everything off in the LockStar app, I still see 2 clocks and status bars.
  • Reset the LockStar app, no effect.
  • Uninstalled the LockStar app, no effect.
  • Restarted phone multiple times, no effect.
  • I tried installing the app again, now it adds a 3rd clock on top of the previous 2.
How do I reset my lock screen back to default? I don't want to customize my lockscreen anymore! 🙏
3 Comments
Hi,
Try clearing app cache.
Ow try performing factory reset, taking back up of your device.
ar4ahmad
Tried clearing app cache and data, it didn't work.
Yes, resetting the phone is the last option to try, but I really don't want to do that.
Hi,
If nothing solving the issues and you know the final option to deal with it then I guess you should give a try.
Good luck 👍
