Fast battery drain after ui7 update, s24 ultra
(Topic created on: 04-30-2025 05:11 AM)
nitinobeid
Beginner Level 3
Anyone facing battery drain problem after the one ui7 update?
7 Comments
blu0wen
I experienced the same after installing oneui7 due to stress on the battery. However, after updating all the apps on my phone ive noticed my battery adjusting back to normal.
nazi532
I have the same issue with my S23 Ultra after installing the update and if you focused you will find that the charging speed become slower( when using wire charger with fast charging off), also the RAM usage has been increased (before the update the RAM usage was between 4.** GB to 5.** GB, now it's from 6.8 GB to 7.6 GB most of time)
Also the location service icon appears on the notifications area near the battery icon almost every 4 or 5 minutes and every time I use any app.
nazi532
nazi532
nitinobeid
Beginner Level 3
Any suggestions to improve battery life?
nazi532
