Using phone call protocol when using ChatGPT
(Topic created on: 08-05-2024 05:21 PM)
abood2rude
Galaxy Z Fold
Is there a way to set the protocol to be via media volume? Because The phone protocol has a capped volume and sometimes it's too low on chat GPT. The protocol that it's set to is the phone protocol just to clarify. Has anyone else experienced this problem?
7 Comments
abood2rude
Galaxy Z Fold
Bump
طارق60
Galaxy Z Fold
مكان زفت زفت زفت
ojwh
Galaxy Z Fold
Hello. Are you referring to the sound/volume?
abood2rude
Galaxy Z Fold
Specifically the sound of a phone call, not media, not noticications, not system, not ringtone. Im talking about sound of phone call. Even when you press the 3 dots on the top right in the volume settings to make the sound louder, all other sounds increase in volume except phone calls. It seems theres a cap from Samsung or a design oversight.
Samsung_specialist
Galaxy Z Fold
You could try these steps to improve call volume:
1. Check if there’s any debris or case obstruction affecting the speaker or microphone.
2. Make sure your device is running the latest software update, as updates may include fixes for audio issues.
3. Go to Settings > General Management > Reset > Reset All Settings. This won’t delete your data but will reset system settings.
4. Check Accessibility Settings: Go to Settings > Accessibility > Hearing > Sound Amplifier, and adjust the settings to see if it improves call volume.
If none of these solutions work, it might be worth visiting a service center for further assistance.
abood2rude
Galaxy Z Fold
Ive already done all that basic troubleshooting. There is simply no option to increase the volume past the cap. Other sounds like media, do in fact increase with the media volume limit increased, so its not a matter of physical debris as well. I just hope that Samsung addresses this issue in future updates as I have already shared this in the error reporting and have received no answer. Thank you, and we would highly appreciate if this is attended to. Regards, abood2rude.
RajeshRana44
Galaxy Z Fold
Hi
