Galaxy S22 Ultra - Battery drains very quickly
(Topic created on: 04-24-2022 07:43 AM)
SamadAK
My s22 ultra Battery drains very quickly i unplug it at 85% and draing very quickly around 4% within 7min .
8 Comments
FarhanMehar
If your smartphone is 1.5 or 2 Years old or new but you are facing severe battery then here are some tips to extend the battery life of your smartphone.
Charge between 25% to 85 %.
Close background services.
Put apps in sleep and deep sleep mode.
Turn off location, only turn on when you need. Decrease Brightness when your phone is not being used.
Turn off AOD.
Turn off sync.
Turn off data or wifi when you don't need it.
Use Power saving mode.
For one week use your phone for very less time, only for need. After one week your battery health will be settled.
Don't use Youtube, FB, Insta or games for one week to set your battery health.
You will see amazing results after following these tips.
Gsara
Beginner Level 3
It's fine
FarhanMehar
Jazak Allah!
SamadAK
Mehar sb did you mean main apna mobile phone use krna choor do 1 week ky liyay
uw3r
Is ur phone up to date
uw3r
7 min is to less claim ur phone in warranty
SamadAK
Yes
FarhanMehar
No bro....just for one week change your mobile usage routine then all things will be alright.
