Battery drain issue
(Topic created on: 05-02-2025 12:56 AM)
Javaidali
Since I updated my Galaxy 24 Ultra to one iu 7, my phone's battery is draining quickly. Can any friend tell me the solution to this problem?
7 Comments
Waqar57
Wipe your phone's cache partition
Javaidali
Thanks for your reply. How to wipe the cache partition?
Waqar57
1. Power off your phone
2. Press and hold the Volume Up and Power buttons until the Android logo appears after the Samsung logo
3. Then go to Wipe Cache and Press Yes with the Power button
4. Restart your phone
Javaidali
Thanks for your advice friend, this method is not working on my phone, cache partition clear mode is not opening.
Javaidali
Thanks friend, the whole process is complete on your advice. Wipe the cache partition. Hopefully, now my phone's battery will work properly.
Waqar57
Good to know then!
Mark my comment as resolved
JazakAllah
Also it takes 15 days to adapt new software according to forums. So just wait
