IamVimal
08-04-2024 01:03 PM in
My Samsung Galaxy S23 Ultra's battery has been draining quickly over the past few days. I've tried running it at 60Hz and FHD+ resolution, but the issue persists. Is anyone else experiencing this problem? If so, how can I resolve it?
RANA_NAJAM
08-04-2024 10:22 PM in
To identify the cause of your phone's rapid battery drain, please review the battery options in your settings to determine which applications are consuming the most energy. If you have recently installed a new application, it is advisable to monitor its battery usage as well. In the event that the issue arose following a system update, it is recommended that you back up your data and perform a factory reset on your device.
Furthermore, it is essential to inspect your charging equipment, including the charger and cable, to ensure they are functioning properly. Utilizing substandard or faulty chargers and cables can potentially damage the battery and contribute to rapid battery depletion.
