S20+ Display Problem
(Topic created on: 08-02-2022 07:02 PM)
tests20plus
Hi all,
Few weeks ago my s20+ display suddenly showed green vertical line and now it has increased to 6 lines of various colours. I bought the phone brand new 17 months ago and the warranty was there only for 12 months. When surfing the net, I see that this is a common problem among many S20 users, most of the time happening just after warranty period. Is there any fix to this other than costly display replacement?
3 Comments
Not applicable
Hi,
It was a common issue that was reported by millions of users, it happens due to the overheating issue which means the heat absorbing components dried of sooner and than its usual five year life.. so because of the heat generat the ribbon pins are heated always it a high-voltage pixel burn..
Solution to this would be replacing the heat absorbing sheats and then replacing its AMOLED panel.
https://www.reddit.com/r/Galaxy_S20/comments/r9dxt3/i_didnt_even_got_any_scratch_or_crack_on_my_s20/
If you found my comment useful, kindly click on the 3 dots and select "Accept Solution"
Thank you 👍.
SK_2000
Sad to hear ... Take your phone to a customer service station. That problem is a defect in the s series product🙁.
If my comment useful ,please accept my solution...😊. Thanks.
Hi... sorry to hear that 😞
This is a manufacturing issue on S20 series. So far the only solution is to replace the display. Sorry to say this, but If you are out of warranty, you may have to pay around Rs. 125,000 for an original display replacement at a Samsung service center. I'm suggesting to you use your current display as much as you can and make sure to backup your phone data to a somewhere secure in case your display is completely lost. Meanwhile, try to use Link to Windows or Samsung Dex when it possible. Sometimes It'll be helpful to slow down the display usage and possibly help to use last long the display. But this is not 100% sure and can't guarantee. Just a suggestion.
