IMS not registered for VOLTE
(Topic created on: 12-16-2023 08:01 AM)
HasanAskari
IMS stands for the IP Multimedia Subsystem, and it is part of an Internet Protocol that also comes pre-installed on all Android devices.
If your IMS registration status is “not registered”, it means that your VoLTE or Voice over LTE is not active, and you can’t make or receive calls and can’t send text messages as well.
It's not a software issue that fixes on next update!
GET IT ACTIVATED FROM YOUR MOBILE COMPANY.
AliRaza4
Bro apka IMS register hogaya franchise sa?
osama512
G hogaya tha. Meri sim me masla tha. Onhe ne new Sim issue ki jis se masla hal hogaya
AliRaza4
Ap mujhy pora gide kren gy kesy hoa hai
AliRaza4
 Mera ya masla arha hai or 4g chlty chlty band hogaya
osama512
Ye ap Force LTE use kr rahe ho? Agar kr rahe ho to wapis default setting kr do. Is app se apka Volte ka masla haal nahe hoga.
AliRaza4
 Nh mena koi forcely lte on nh kiya
Talha917
What was your problem I am a jazz sim user too .my calls don't work but data does
aoluwolepeter
The issue is from your network provider. I have two sims in my phone, sim 1 ims is showing me not registered while sim 2 shows me ims registered. Moreover, my sim 1 doesn't show VoLTE which means my network provider hasn't activated it from their end while sim 2 always shows VoLTE.
In conclusion, the problem isn't from your phone but from your network service provider which is yet to activate VoLTE for your phone model.
galiii
I have the same problem can you guide me what to do to activate the ims
Aflatoon07
My sim is volte activated and volte is working in another 4g devices but not working in my samsung f23 5g handset but other sim volte is working and even volte option is not showing for any sim in my device .....plese guide or help me.........
