Pink Line Issue samsung note 20 ultra pro
(Topic created on: 02-16-2025 12:05 PM)
nehashabbir
Dear Samsung Support Team,
I’m facing a Pro Line issue on my Samsung Note 20 Ultra, where a colored line has appeared on the screen. It’s affecting the display, and I’d like to know how to fix it.
12 Comments
user9992112
Display replacement is the only option
nehashabbir
But yeh issue software update krth waqt aya hai
MahadScorpio
I had a OnePlus before my current phone, or uspar bhi same issue tha, couldn't solve it 20250202_013543_1000016442_1738442145.jpg
nehashabbir
MahadScorpio
I think replacing the display is the only option, my OnePlus had the issue and so i changed the screen, and then it happened again 😭
nehashabbir
nehashabbir
What to do if this problem is done again after getting the screen change
MahadScorpio
I mean I wasn't risking the same again so i used it with the lines on the screen for a while and then bought a new phone when i could
aakashnawab7
OnePlus ka display bhi Samsung hi manufacture krta h. Samsung or OnePlus ka common issue hai.
Damage se bhi aa jaata h. Na aaye to update krne se laazmi aa hi jaata h.
