IMS not registered for VOLTE
(Topic created on: 12-16-2023 08:01 AM)
HasanAskari
IMS stands for the IP Multimedia Subsystem, and it is part of an Internet Protocol that also comes pre-installed on all Android devices.
If your IMS registration status is “not registered”, it means that your VoLTE or Voice over LTE is not active, and you can’t make or receive calls and can’t send text messages as well.
It's not a software issue that fixes on next update!
GET IT ACTIVATED FROM YOUR MOBILE COMPANY.
27 Comments
How?
HasanAskari
Call them
user9992112
Yes, VOLTE requires activation from the carrier.
osama512
Hello. I have tried every possible way to activate Volte but it's not working. I have called the carrier multiple times, and they say it is active from their side. I have swaped sims, i have tried the sim in my other phone, i did network reset and apn reset but nothing is working. Kindly help me out1706446282487.jpg
HasanAskari
Brother, just check if your VOLTE working on any other mobile. As you Sim might be old and have issues.
If it's working fine on another mobile there is an issue with your cellphone software and that will be fixed in coming update IA
osama512
Nah bro it isn't working in my A10s too. Plus Sim is new. I bought this sim last year. Currently using Galaxy A32
sagi66
hi i find this trade and i have a qustion , i am a manager in an MVNO company , we want to update our new IMS for volte in samsung divises .
who should i contact in samsung in order to start the prosese ?
do you know ?
ismailkhani
If you still have this issue, I recommend that you must visit jazz franchise and they will activate it for you. I had the same issue and upon visiting customer centre, my issue was resolved in less then 5 minutes
osama512
Bro, the issue was resolved after i visited the franchise. My Sim (which was new) was defective.
