Kamii2000
04-19-2025 03:13 AM in
I recently purchased the s24 plus. It a almost new set, and I have personally activated CPID on it. I am quite frustrated with its battery drain issue. The battery drains from 100 to 20 in 5 hours at standby mode. I have checked all battery settings. The refresh rate has been set at 60. The performance has been set at light. The battery protection has been set at basic. What are my next steps?
2 Comments
Gamechanger55
04-19-2025 03:20 AM in
Try to turn battery mode to normal mode ..
If didnt work try to go in the safe mode so you will get to know which app is draining battery so much
ASIM-ANSARI
04-19-2025 03:45 AM in
Ye Tu bohat zyda drain ho rahi ha
