S24 Ultra Battery Drain issue ..
(Topic created on: 04-24-2026 02:09 AM)
DrSaim
Hi everyone,
I’m facing a serious battery drain issue on my S24 Ultra. The problem started right after I performed a factory reset. Before the reset, the battery performance was completely fine, but now it’s draining much faster than usual even with normal usage.
Has anyone else experienced this after a factory reset? Any idea what could be causing it or how to fix it?
Would appreciate any practical solutions. Thanks.
