Automatically restart or Froze problem
(Topic created on: 01-21-2022 10:14 AM)
شیرخان
Dear Sir , There comes an problem in my mobile after updating the software last month on 19 date.
While using mobile it turns off automatically and froze sometimes. I don't know what type of problem is it.
This Error or fault starts when I update the Samsung A21s Software.
 Please guide me or give me some details about this or launch the new software and fix this problem.
Thank you.
10 Comments
_Usman_
Wait until the next update or just do factory reset on your device..!
شیرخان
But I cannot do the factory reset 😕 sir
شیرخان
I will loose all my data and other important things
_Usman_
Backup your data to any external storage. Its very easy..!
eyeshabutt
Frist restart your device
SyedUsama1915
Respected Sir,
You may copy yours personal data into ur pc or laptop
Or simply backup your data on Google photos .
#Best regards
#Syed_Usama..
MHashimKhan
Sher Khan
This problem may be in your settings. Please again check your settings your problem will be solved if not than you should send your data log to samsung for checking actual problem.
iwqskh
Same problem mery A52 mei hai pr ik he dafa huwa hai esa.. whatsap open ki thi fr froze huwa or fr Samsung logo aa gya.. pr abi tk esa kuxh nhi huwa
hunainjumani
Samsung a21s automatically restar
