Problems QnA#1
(Topic created on: 01-12-2022 01:12 AM)
MuhammadAhmadMaqsood
If you are facing any type of issues regarding your device than you tell me. I'll resolve it, if possible.
11 Comments
eyeshabutt
Apko kaya problem ah rahi
I ask from you, if you are facing any type of issues regarding your device than you tell me.
None
awais993
Why samsung phones changing time is effected during summer season ? I know there is temp issue you may say. But other brand phones charging is not effected by hot weather. Why samsung is not looking into this matter??
eyeshabutt
Go to my post I post details
In summer season due to the increasing temperature the battery efficency is decreasing other chinese brands use liquid cooling technology in phones while Samsung does not use any type of of liquid cooling technology which helps mobile during summer vocation to cold down
Hope so you understand bro
But the difference is very small in the warm feel of Samsung in comparison of others
But you are right samsung need to work on this matter because this is now compulsion to provide a liquid cooling motor in mobiles
Muqaddar
From last night my phone is charging about 5 hours from 0. To 100
While phone is showing command of slow charging on screen .No +ive results by changing chargers and cables
Muqaddar
Sorry I have Note 8 us version
It is because of battery the battery efficency is about to end due to long term use
