Samsung Galaxy Note 9's small problem
(Topic created on: 05-21-2021 08:24 PM)
shafeek159
Galaxy Note
Now im using Samsung Galaxy Note 9 . Bt android version is 9 . How to update android 10
7 Comments
noahm
Galaxy Note
How come you still have Android 9 if you have a Note 9???
You should already have Android 10.
It released for the Note 9 series back in 2019 Dec - 2020 Jan!!
Or are you talking about Android 11? If Android 11, you won't get it officially as the software support policy in 2018 when Note 9 released was to give 2 OS upgrades only. So Android 10 is your last OS upgrade. You will get the security updates though.
If you want Android 11, you will have to flash it.
Note 9 updates release doc: https://doc.samsungmobile.com/SM-N960F/SLK/doc.html
shafeek159
Galaxy Note
I got this phone only one year ago
noahm
Galaxy Note
Doesn't matter when you bought it. Even if you buy the model a year later the support policy enables upgrades according to the model's release date.
If you bought a Note 9 last year, that's 2 years later since its official release. Why did you buy an old model instead of a new one?? 😳
shafeek159
Galaxy Note
How I flash bro
noahm
Galaxy Note
I don't recommend flashing the device on your own if you are new to it. If not done correctly, your phone can become unusable.
Try to get it done from a person who knows how to do it properly.
But I will just comment the guideline links. May be you can go through them.
To flash, you should make sure that your device’s bootloader is unlocked and you have TWRP installed.
To unlock bootloader, first you have enable developer options, then enable the options "OEM Unlocking" and " USB Debugging". Then you have to use ADB (Android Debug Bridge) installed in your PC/laptop to unlock it.
Refer this article for the guide to unlock the bootloader:
https://www.lifewire.com/how-to-unlock-bootloader-android-phone-4689186
Refer this article for the guide to install TWRP:
https://www.xda-developers.com/how-to-install-twrp/?amp
After both of these are done, back up all your data.
You can refer below article provided by XDA regarding flashing Android 11 to your device:
https://www.xda-developers.com/samsung-galaxy-note-9-one-ui-3-1-android-11-port/amp/
You can check the flashing guide and download the Android 11 custom ROM from here:
https://forum.xda-developers.com/t/noble-rom-1-3-oneui-3-1-full-port-05-21-patches-14-05-2021-sm-n96...
shafeek159
Galaxy Note
Thank you 🥰
shafeek159
Galaxy Note
How can I upgrade my phone
