note 9 battery issue
(Topic created on: 01-27-2021 12:54 AM)
Uzi8282
Others
Hello there! I also have serious battery issue .. i have been using this devixe since 1.5 years and now from almost 2 to 3 months i am facing battery drain ..i had turned off almost every function and apps with power saving on .. and still battery is dropping 7 to 8 % every 30 t0 35 mins while screen is off.i didnt even turn on any feature ..all my apps are on deep sleep still same issue..anyone help me please
4 Comments
Uzi8282
Others
any solution ?
AliRazaShafi
Others
try hard reset.
Uzi8282
Others
sir . i didnt try hard reset but tried normal reset it didnt work
arbabazhar
Others
replace battery
