Note 9 battery drain issue
(Topic created on: 08-28-2019 05:11 PM)
Ali_karim
Others
My Note 9 battery drain so fast. Even at night it falls 4 to 5% in standby mode. And consistently falls when i used it..can anyone have any idea how to fix it???
12 Comments
choclate6
Others
r u using original charger ?
Ali_karim
Others
yes..
suhailahmed
Others
use greenify app its help a lot
Nawab_khan
Others
4 to 5% drain on standby is usual..
few things you can try,
1) turn off "device administrator"
2) turn off "Remote Control"
3) turn off " wifi and bluetooth scanning in Location"
4) turn off " near by scanning"
5) turn off "lift to wake"
6) turn off " smart stay"
Nawab_khan
Others
battery drain on standby is also caused by low signal strength
Ali_karim
Others
full signals..everything you said off...
Nawab_khan
Others
did u observe battery consumption which thing is on the top after screen?
Ali_karim
Others
chrome, twitter, whtsapp
Nawab_khan
Others
go to settings and then apps..
search Chrome and tap it..from there, go to storage, clear caches and data..lastly, update Chrome from play store.
